Why is my printer only showing up to print faxes and not printing?
My printer doesn't allow me to print. I downloaded it again and all it does is show up as print faxes. What do I do?
Es esta una buena pregunta?
When you click on print there will be a box come up and in that box will be "printer" somewhere depending on the version of windows you have . Where it says printer there is a drop down box in there you will see different choices make sure you select the printer . The first on the list is usually the fax as things are listed alphabetically. Hope this helps
Fue útil esta respuesta?
There is no other choice, only the fax when I scroll down.
I have the same problem. Only option is to fax and when I try to print the "see what's printing" looks like it is printing but the machine thinks it is sending a fax. I have never had it set up with a phone line to fax. What changed and how can I get my printing option back?
Is anybody seeing these questions?
Remove the FAX Hp printer using disable driver options OR devices and printers from control panel. Then select the normal printer settings and enable that on network. That should take care of it. Usually these issues arise as you tend to install FAX using HP software.
Ultimas 24 horas: 0
Ultimos 7 días: 10
Ultimos 30 días: 32
Todo El Tiempo: 14,958
1 comentario
Is the date and time on your computer holding when you are not on the internet?
- de mayer
