Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
La única versión wi-fi del iPad Air de Apple, número de modelo A1474. Disponible en Space Gray o Silver, incluye el procesador A7 personalizado y se envía en configuraciones de 16, 32, 64 y 128 GB.
not charging... no 3.3v... power manager?
Hi guys... I', struggling trying to solve an issue with this iPad Air...this is the scenario: while off, when connectin lighting cable it switches on but it does not charge the battery... what\s weird is that there is no "not chargin" message near battery icon... simply nothing.
Analyzin with multimeter there are no shorts at all in the board, but 3.3 volts rail is completely missing..... all the other voltages are present. I tested continuity between dock pins soldered to the board and checkpoint and everything is ok... I already replaced the charging IC (U6000) but no result.... each and every smd belonging to PP3V3_ACC line is good and functional... should I replace the power manager (U8100) or anyone of you can suggest me other solutions? thanks everyone in advance....
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Solución Elegida
The PP3V3_ACC line is only present when the phone powers on. Otherwise, unless there is an accessory plugged into the Lightning port, you don't need to worry about it.
Did you check all the rails generated by the PMIC, there are a few dozen?
Perhaps your Tristar replacement did not succeed and you should try it again.
EDIT
This is the Tristar circuit. Check the following voltage rails
PP3V0_S2R_TRISTAR
PP1V8_S2R_TRISTAR
PPVBUS_PROT
(but not PP3V3_ACC)
You should be able to find the schematic on the web
Fue útil esta respuesta?
Puntuación 1
3 comentarios:
and could you tell me what are exactly the rails to check, the ones involved in battery charging process?
- de
the voltage rails you mentioned are present... I thought the problem was in PP3V3_ACC just because battery is not charging.... so confused :-(
- de
As I said, perhaps your Tristar replacement did not succeed. You should also check all the PMIC rails, the problem could be elsewhere. Good luck!
- de
Añadir tu respuesta
Dolcebimbo72 estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 10
Todo El Tiempo: 983
