Saltar al contenido principal
Anunciada en octubre de 2013, la Nikon D5300 es una DSLR de nivel de entrada superior con un sensor de tamaño DX de 24Mp.
Preguntas 41 Ver todo
"Zoom Out /? " Button is unresponsive.
Zoom Out / ? Button is automatically pressed even without touching. When double pressed of pressed hard it keeps responding neatly for 5 mins tops. and after same problem. Do I have to replace the back panel key board or any repairs can done by myself? Please help me out.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
1 Respuesta
Respuesta Más Útil
it is most likely that there is dirt or something causing the button to stop working or to start working randomly of it own accord. you'd need to remove the back cover to expose the button contacts and give them a good clean, worst case scenario you'd be buying a rear cover button flex cable fpc.
it can be a fiddly job with screws hidden all over the place, there is no guide on iFixit to do this but there are guides for similar models like the D5200.
follow this guide to removing the back cover, once you have the back cover off its a pretty simple job to remove the ribbon cable and clean or replace.
Nikon D5200 Motherboard Or Camera Back Replacement
Fue útil esta respuesta?
Puntuación 1
Añadir tu respuesta
Amila Yohan estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 1,011
