wifi does not work
I need help with my Asus z580c, the wifi is like death, it does not work, you start it but nothing happens, when yo seek into hardware info, it appear wifi undetermined
Es esta una buena pregunta?
i solved, open the table, disconnect the battery, remove the sd card put it on again, reconnect the battery.
Ah voila there is again the wifi connection.
Fue útil esta respuesta?
this helps, thank you. i took it to power off, removed sdcard, restart and its working.
I just powered down and removed the SD card and that fixed the problem.
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 645
