Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
The Moto G4 Plus is an improvement on Motorola's Moto G4. The Moto G4 Plus offers a fingerprint sensor, increased memory capacity, and an improved rear camera. Model number XT1642 and XT1644.
moto g4 plus Micro USB Replacement
Can you put up a video on how to replace the micro usb port on the moto g4 plus?
Mine had the plastic literally melt after connecting in to an apparently faulty car charger.
Much Thanks and keep up the great videos!
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 5
4 comentarios
Your phone didn't warn you what was happening?
- de
Hi, did you solved this problem? I need to replace my charging port too.
- de
Nope, ended up sending it in on warranty and getting a new phone.
- de
Hi
I purchased a rebuilt Moto G 1st generation smartphone but the charger port was broken after I paid for it , and before I received it.
Can you provide an instruction manual or video? I have seen one but the soldering alone I know is more than I can do myself. Can you help?
- de
Agregar un comentario
1 Respuesta
Respuesta Más Útil
william_oliveira87, John Linden, If port is found to be bad/loose/damaged , this is really not a repair for the inexperienced because the charge port for your device is soldered to the mother board and the heat generated could cause further damage if not very careful. I will post a link to a tear down guide to get you inside the tablet to check the charge port and will also post a link showing what is involved in repairing a USB charge port attached to the board. The last link is to new charge port, which you can also do a search for better pricing perhaps if needed. If not wanting to do the repair yourself have a good computer/cell phone repair shop have a look and estimate repair. Good luck.
https://www.youtube.com/watch?v=8jqw-KwC...
https://www.youtube.com/watch?v=Bl_6g4GV...
http://www.ebay.com/itm/2X-Dock-Connecto...
Fue útil esta respuesta?
Puntuación 7
Añadir tu respuesta
John Linden estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 12
Ultimos 30 días: 51
Todo El Tiempo: 10,807
