MacBook air battery not charge, ornage light on charger (water damage)
Hello everybody!
I've been trying to fix water damaged Macbook Air for few months now, and running out of ideas.
So I go Macbook Air 13" Early 2015 what was got lquid (Beer) on keyboard. When i got it, it was total dead. I toke it aparts, clean motherboard and everything else with alcohol and let it dry good. I put it back together and blugged it in, pres power button and it came alive. So good so far.... But...
There is a power problem. MBA stays on with power adapter only. It works fine with it but not charge battery at all. If I unplug it, it will immediately shuts down. Battery Status was before says 83% then 72% and now it is 68%. When plug AC adabter, the led on adapter turns green for second and then goes orange, so it thinks it charge...
Here is battery information:
Charge Information:
Charge Remain (mAh): 4607
Fully Charged: No
Charging: No
Full Charge Capacity (Mah): 7047
Healt Information:
Cycle Count: 17
Condition: Nomal
Battery Installed: Yes
Amperage (mA): 0
Voltage (mV): 7887
AC Charger Information:
Connected: Yes
Wattage (W): 45
Family: 0x00ba
Serial Number: 0x00a9700d
Charging: No
I have reset PRAM and SMC, not helping. I have connected and disconnected battery many times and no luck with that either.
If somebody have Ideas for that pleas replay
-Miki
Es esta una buena pregunta?
Did you find a solution for this? I am also facing the same issue after I dropped water on the macbook pro 13" early 2015. The orange light is lit but the battery is not charging, and the computer turns off as soon as you disconnect.
- de Satish U
