Saltar al contenido principal
The Asus X200CA laptop is 11.6 inches and weighs 2.6 lbs. It comes with a either an Intel® Core™ i3 3217U Processor, an Intel® ULV Pentium® 2117U Processor, or an Intel® Celeron® 1007U Processor, 2 GB or 4 GB of RAM, 320 GB to 1 TB of storage, Windows 8 OS, HD webcam, and an estimated battery life of 3 hours.
Why it wont charge
its not charging nor turning on why
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
1 comentario:
Did this happen out of no where? What is the history of the device? There isn't a whole lot of information to be able to provide an answer to your question.
- de
Agregar un comentario
1 Respuesta
Plug is Not Connected to Wall Outlet
Check to see if the charger is plugged into the computer and also an outlet. Try a different outlet to ensure that it is not a problem with the power of the first outlet.
Dead Battery
If your laptop will only function while being connected to an outlet, your battery may be faulty. To fix this, replace your battery.
Damaged Battery
If your laptop will not turn on, check your battery for any physical damage or water damage. If you find evidence of damage your battery will need to be replaced.
Issue with Charger
Check to see if the charger is one that is recommended to use by the manufacturer. If not, obtain a recommended charger. Check to see if your device will charge with a different charger. If this is the case you will need to replace the charger you have.
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
tinner estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 2
Ultimos 30 días: 2
Todo El Tiempo: 452
