Saltar al contenido principal
The fourth generation of Honda Accord covering model years 1990 through 1993 available in coupe, sedan, and wagon chassis.
Wont start at time.
Hi. I have a 1992 honda accord. I was having issues with the starter. It was making noises and sometimes it won't crank and usually I would have to sit for a while before I can get it to crank. I bought a new starter and it would start but that ugly noise when I crank was still there. Drove the car like that for a while now is doong it again. Any idea of what wrong. Also the battery is fairly new.
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Solución Elegida
3liezer torres, there could be a problem with the teeth on the ring gear,flex-plate/flywheel which the starter has to engage into to turn engine over. When cracked/damaged/worn teeth on ring gear could intern damage the new starter. Remove starter, using a flash light look in starter hole, turn engine over by hand and inspect the ring gear/flywheel/flexplate carefully for wear/damage while rotating or have it checked by a good mechanic if you are not comfortable doing so. Below are links to show part that may be your problem and how to replace. Good luck.
https://www.youtube.com/watch?v=j_sgiTa3...
http://www.autozone.com/repairguides/Hon...
Fue útil esta respuesta?
Puntuación 1
2 comentarios:
Thank you. I noticed when I took out the old starter that the teeth were pretty beat up. Thanks your advise help tremendously
- de
3liezer torres, thank you for your response, if making the repair yourself be careful/work safely and use jack stands, etc. try to have a good day.
- de
Añadir tu respuesta
3liezer torres estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 5
Todo El Tiempo: 318
