Saltar al contenido principal
How to upgrade the M.2 SSD
Dear ifixit team,
I have an HP Spectre X2 Detacheable 12 inch tablet. However, the unit comes with a 128GB M.2 2280 ssd. Does anybody know on how to open the unit in order to replace this ssd with a larger capacity? Thank you so much for your answers. Regards Surfix007
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 7
Agregar un comentario
3 Respuestas
Respuesta Más Útil
Here is the "end of life" recycling guide that shows some basics on how to take the spectre x2 apart. Would be a good place to start on a project like replacing the SSD.
http://h22235.www2.hp.com/hpinfo/globalc...
Fue útil esta respuesta?
Puntuación 2
2 comentarios:
I have HP Spectre X2 12-a009nr. Theres no 4 screws like in the link that you provided :(
- de
I think you need to follow this guide: http://h22235.www2.hp.com/hpinfo/globalc... . If so then I won't touch it as it is glued together.
If, however, you have found a solution please let me know as I would also be interested to know
- de
Puntuación 0
you can open the machine without removing the screen from the bezel.. use a spudger between the black plastic bezel and metal frame. It will pop off easily, and reinstall with no glue. I take mine apart for fun. the drive is a standard m.2 sata ssd
Puntuación 0
1 comentario:
Start in the upper right corner near the power button.
- de
Añadir tu respuesta
Rainer Michelis estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 8
Todo El Tiempo: 2,319
