Saltar al contenido principal
El iPhone 5c de Apple fue anunciado el 10 de septiembre de 2013. La reparación de este dispositivo es similar a los modelos anteriores, y requiere destornilladores y herramientas de entrometimiento. Disponible como GSM o CDMA / 8, 16, 32 GB / Blanco, Rosa, Amarillo, Azul y Verde
Preguntas 1233 Ver todo
iPhone 5c won't charge past 3%
My iPhone 5c won't charge and the charger is brand new but after I plugged it into my moms Dodge Journey USB port my phone stoped charging , now it dies and turns back on but doesn't charge past 3% and the lighting bolt doesn't pop up , does it need a new battery ? Help
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Solución Elegida
The iPhone charging subsystem can be damaged by non-MFi (Made for iDevice) certified chargers. Based on the sequence of events you describe, this is what happened to your phone. Cheap dollar-store charging bricks also can cause this.
While it is possible that your battery is defective, I believe that the Tristar(U2) IC on your device was damaged by the USB port. This is not a DIY repair unless you have experience in micro-soldering.
If you have access to a known-good battery, you can always replace it. If a known-good battery does not charge, then it is a U2 problem.
Reemplazo de la batería del iPhone 5c
The 5C also suffers from micro-fractures on the logic board so this could also be the root problem on your device. A qualified repair shop that does micro-soldering should be able to troubleshoot your device properly if you don't want to do it yourself.
Fue útil esta respuesta?
Puntuación 1
Añadir tu respuesta
Shadiamond estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 3,879
