Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Segunda generación de iPad con Wi-Fi, lanzado el 11 de marzo de 2011. Número de modelo A1395. La reparación es difícil y requerirá calor.
Preguntas 330 Ver todo
iPad 2 Wi-Fi EMC 2415 battery not charging
After a screen replacement my ipad will no longer charge is it possible that the battery or charging circuit have been damage and if so how do I test this.
Es esta una buena pregunta?
Puntuación 2
Comentarios:
Thanks Chris
Yes I done to repair myself replacing smashed screen. There is no light on screen when plugged but i will check the items you have suggested and take it from there.
James L
- de
Update
Thanks Chris
yes it solved the problem it was not making correct contact thanks again and have a happy and safe xmas
James
- de
Agregar un comentario
1 Respuesta
Solución Elegida
Hi James, Did you do the repair yourself or through a repair shop? Either way its very possible that the ribbon cable could have been damaged or even melted when the screen was removed. First I would plug your charging into your ipad give it roughly 5 second and check to see if you have any sort of background light turn on. If you do its not your charging port. Also its possible that the ribbon cable connection was not seated properly on the logic board. If your charging cable still shows signs that it is charging your batter could be bad and may need to be replaced.
I hope that helps!
Best of luck,
Chris D
Fue útil esta respuesta?
Puntuación 1
Añadir tu respuesta
James Lloyd estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 106
