Saltar al contenido principal
Procesador 1.5 Core Solo, 1.66 o 1.83 Core Duo, o 1.83 o 2 GHz Core 2 Duo
Anyone found an alternative Mac Mini outer casing?
Hi! I recently acquired a 100% functional Mac Mini from a recycler, the only catch being that the outer casing has been destroyed, and so the guts of the Mini are exposed, and it's not really in re-saleable condition. I've looked into replacing the casing, but it seems a little silly to spend $50-$100 that people are asking.
Does anyone have thoughts on a practical alternative to Apple's Mini case? I'd prefer something on the practical/discreet side, as opposed to goofy and outrageous.
Thanks!
Es esta una buena pregunta?
Puntuación 1
1 comentario
If you end up with it in the cube case or the floppy disk drive, you should take some pics and link them here so we can take a look at what you did.
- de
Agregar un comentario
4 Respuestas
Solución Elegida
How about a nice ammo box. Lay it on its side, cut the top for the CD drive. Larger boxes could be used for extra hard drives. Comes with a carrying handle.
http://www.amazon.com/Military-Ammo-Wate...
For a bigger box, use the 50 cal version: http://www.amazon.com/Military-Surplus-C...
Here's a bunch of various goodies: http://www.colemans.com/ammocan.htm
Consider using the dome from a iMac G4 with out the screen attached.
Fue útil esta respuesta?
Puntuación 3
6 comentarios:
Or an old mac cube case would be awesome! but the little research I did I couldn't really find one for much less than $50.
- de
Awesome idea Mayer! I'm going to seriously consider it...my only concern is that the metal might keep wireless from working, but I'm sure there are ways around that.
R Trent, thanks for the idea...I have an old Cube around, so I'll see if it fits...that would potentially be a fairly easy solution.
- de
good answer +
- de
Yeah WL might be an issue- also it'd add a TON of weight, probably not good for ventilation either though, do you have a CNC machine?
- de
The cube's a great idea- in fact, it's upgrading the Cube so you get some sort of Mac Cube? Cube Mini? Whose origins cross processors and years.
- de
Mostrar 1 comentario más
Here is one that mayer came up with on Meta that I really like.
http://www.pcworld.com/article/170973/co...
Puntuación 3
3 comentarios:
Oh wow, that is amazing!!! I just finished putting it into a Cube case, but I think I'm going to buy an Apple floppy drive on eBay now, cuz that's just too cool to not try! :-) Thanks!
- de
legitt +
- de
+ I forgot about that one. It's good.
- de
How about buying a cheap generic mini-pc case? You can also often get those with a built in power supply, which is useful.
Puntuación 1
3 comentarios:
For example, a quick eBay search turned this up, I'm sure you could get much cheaper with more thorough searching, and for Used as opposed to New parts
- de
Great idea Rab! I'll take a look.
- de
Duct Tape
Puntuación 1
1 comentario:
I like the idea, but wouldn't that run the risk of making the computer overheat?
- de
Añadir tu respuesta
rdklinc estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 7
Ultimos 30 días: 49
Todo El Tiempo: 4,480
