Saltar al contenido principal
Pilot not holding Goes out after let go the button.
Hello... trouble with the water heater.
First the pilot wouldn't lite.. so i turned it off for 10min to clear the gas and tried
it again and the pilot worked. I hold the pilot button down until the status flashes but
the pilot goes out when i let go the button. I was told there is a reset button so i pushed what i thought was the reset but it doesn't push or click. Any thoughts?
Es esta una buena pregunta?
Puntuación 1
1 comentario
Tested the Thermopile and the mV reaches above 500 mV and continues to go up after about a minute of holding down the pilot button, but as soon as you let it go it drops back down to almost nothing.
- de
Agregar un comentario
1 Respuesta
Solución Elegida
@cameraparts4you , Be extremelly careful working with your gas appliance, if unsure contact a Qualified Technician. Dirty TC( thermocouple), faulty TC, pilot flame to not set properly/small or not close enough to TC, partially plugged pilot tube, faulty/bad gas control valve, all could cause pilot not to stay lit. Check the attached links troubleshooting,instruction, Good luck.
http://www.doityourself.com/stry/reasons...
http://www.home-repair-central.com/gas-h...
Fue útil esta respuesta?
Puntuación 4
Añadir tu respuesta
Sales Cameraparts4you estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 35
Todo El Tiempo: 24,405
