Heater core replacement 1997chevy malibu
The easiest way to change heater core
Es esta una buena pregunta?
In most cases you have to tear most of the dash out and remove most of the ventilation duct work. I have seen cars where the owner cut the ductwork out with a saw and replaced the core and then used duct tape to put it back together. I dont advise you do this . Its usually a long and involved job. If the core is not leaking ,just not producing any heat try this video before removing the core. Its a whole lot easier than replacing the core. Hope this helps
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 7
Todo El Tiempo: 3,824
