There is no sound coming from my speakers.
I have no sound coming out of either the speakers of the headphone jack. The volume option is not even available in the taskbar.
Es esta una buena pregunta?
Is the sound card shown in the device manager as installed and working correctly?
click on the windows button + X and choose "Device Manager" from the menu.
In the device manager are there any devices under "sound, video and game controllers" ?
Fue útil esta respuesta?
No there are no sound cards or any other sound options in the device manager
Have you installed the Audiodrivers from Asus homepage?
Generally, people get into the sound problem due to the several reasons.
Now check the mute button and reboot the laptop. here, is the quick option to fix the problem. if you need to fix the problem you can simply visit : fix asus laptop sound not working.
If you are an Asus ROG user, you might have come across the problem of sound not working on your laptop. This can be a very annoying problem, as you will not be able to hear any sound from your laptop. In this article, we will show you how to fix Asus ROG sound not working problem.
I'm having a problem with my Asus Rog sound not working. Whenever I try to play a sound, it just says "Fix Asus Rog sound not working." I've tried reinstalling the audio drivers, restarting my computer, and changing the audio settings in my computer, but nothing seems to work.
First of all, you need to make sure that the sound drivers are installed properly on your laptop. You can do this by going to the Control Panel and then clicking on the ‘Sound’ icon. Once you are in the Sound options, you need to click on the ‘Hardware’ tab and then look for the ‘Asus ROG’ device. Right-click on it and select ‘Update Driver Software’.
If the above method does not work, you can try uninstalling and then reinstalling the sound drivers on your laptop. To do this, you need to go to Device manage by doing right click on window icon from task manager. Tap on Audio inputs and outputs. Right click on the driver and then Uninstall it. Now restart your pc and let window find and install appoprite sound driver.
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 3
Todo El Tiempo: 1,730
