Why does my 2005 Equinox keep stalling while driving .
Why does my Equinox keep staling while driving.? I have already changed the park neutral safety switch and it does the same thing.
Es esta una buena pregunta?
Ricky, have the vehicle scanned for trouble codes as a first step to help diagnose your issue as there are a lot of things that could cause this issue. Some auto parts stores will read your trouble codes for free like Nappa, Pep boys, Autozone, etc..
Maybe see if you are on or if your 2005 Equinox had the Computer changed, faulty PCM which is covered under a NHTSA Recall, as this is one of the symptoms for the recall. More info on this at link below.
Fue útil esta respuesta?
Really excellent research ;-)
Ultimas 24 horas: 1
Ultimos 7 días: 4
Ultimos 30 días: 8
Todo El Tiempo: 3,552
2 comentarios
When it stalls are you at speed or sitting at a corner. does it bog and die hesitate when accelerating will it idle and if so is it a smooth idle or is it erratic . Are there any MIL on ?
- de Jimfixer
Did you fixed the problem?
- de Albert
