Saltar al contenido principal
Microsoft Surface 2 fue fabricado por Microsoft Corporation y es la segunda generación de tabletas de Microsoft. Fue lanzado el 22 de octubre de 2013 e incluye funciones como potencia de procesamiento mejorada y resolución de pantalla.
Preguntas 20 Ver todo
Change Battery Microsoft Surface 2
How do I replace the Microsoft Surface 2 battery?
What material should I use to assemble the screen with the back cover?
Es esta una buena pregunta?
Puntuación 2
3 comentarios
I must disconnect the display from the rear panel with a heat gun, then to reassembly the Surface, I will have to use glue to assemble the tablet?
- de
What should I use to connect the ribbon cable to the motherboard?
- de
How do I remove the battery after removing the motherboard?
- de
Agregar un comentario
1 Respuesta
Solución Elegida
@piero90, Piero, remove the old glue/tape with a (little) heat and a plastic scrapper/credit card/fingernail, then use some 90% isopropyl alcohol and a lint-free cloth to clean the remaining adhesive. Use a good quality thin 2 sided tape to put back together, which you can find doing a google search/hobby shop/small electronics repair store when you figure which width would work for you. Links below show tear down of the Surface 2 and adhesive strips being applied. Check the attached links,instruction and guides, Good luck.
http://www.techrepublic.com/pictures/cra...
https://www.youtube.com/watch?v=Man6w3sd...
Fue útil esta respuesta?
Puntuación 4
22 comentarios:
How I remove the ribbon cable in the Microsoft Surface 2?
- de
@piero90 , Piero, at 27.00 min's in on video shows ribbon cable removal and the 2nd link here shows more detail of the cables removal, good luck with your device.
Microsoft Surface 2 Screen Replacement
- de
Then I have change the battery, I must to use glue or thermal past to reassemble the tablet?
- de
@piero90 , Piero, it would probably be best to reapply the thermal paste if removed and glue to a like factory install to prevent possible problems. Have a good day.
- de
So I must to use the glue and the thermal paste together?
- de
Mostrar 17 comentarios más
Añadir tu respuesta
Piero Sabino estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 8
Ultimos 30 días: 22
Todo El Tiempo: 4,221
