Saltar al contenido principal
Cannot fully charge battery
The phone was fall down and cracked , screen was broke and battery get very fat. Screen was replaced sam as battery. Then I can't fully charge the bat , fast charging work almost perfect but only to 67% the charging was about 1pc for a 8min and stops at 70 % (still got information about fast charge). I've buy the second one battery and problem is still in my phone, so I flash the other rom, hard reset, cleaned battery connector and main board with alcohol. Everything is still same. Any suggestions?? Used only original parts.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
1 comentario:
I solved the problem. The cause of this problem was a problem with found an original battery, i found a trusted wholesale in my country and finnaly they send me the 100% original battery.
Problem solved.
- de
Agregar un comentario
2 Respuestas
maybe your power charge sample resistance of phone's main board was broken!check your motherboard!
Fue útil esta respuesta?
Puntuación 0
2 comentarios:
Where to find it, got any scheme ?
- de
check voltage of keypiont,look for power charge chip,and replace new one,no scheme
- de
Got the same problem...
Puntuación 0
Añadir tu respuesta
Piotr Kaszewski estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 8
Ultimos 30 días: 10
Todo El Tiempo: 184
