Saltar al contenido principal
Modelo de principios de 2011, A1278 /2.3 GHz i5 o 2.7 GHz con procesador i7.
Preguntas 782 Ver todo
MacBook Pro won't detect internal display
Hi!
It's my first time in the forum and my last hope!
I am with this macbook pro 13-inch early 2011, but when you turn it on the display refuses to react, it doesn't show anything, even the apple logo on the back doesn't glow.
If an external monitor is plugged, it works fine and square, even tough the OSX (el capitan) doesn't doesn't consider the existence of a built in display in the laptop
I've tried p vam reset, battery insert/removal and other sorts of unusual practices, and none seem to bring results
I would say the LCD is dead, BUT if I boot on the bootcamp, the windows startup as expected and the display turns on just as a perfect one would do...
So, I don't have any clue of what is happening and decided to share my situation here, so any help would be very welcome
UPDATE:
After letting Macbook idle for sometime (connected to the external display) , after waking it up, the built-in display worked good. Then I restarted and again the blackscreen status, but coudn't get the internal display to work anymore
Es esta una buena pregunta?
Puntuación 1
2 comentarios
Yeah, PRAM/// SMC and others as well
- de
Agregar un comentario
5 Respuestas
Solución Elegida
Please restart in Safe Mode (by holding down the Shift key) on start up and let us know if it works. This should tell us if it is a software issue, which I believe it to be. That failing, start up holding down the R key, next try the option key and see if you can choice the repair partition. I suspect either virus or corrupt GPU drivers. What OS X are you running?
UPDATE
Try staring in Recovery Mode, run Disk Utilities.
To enter this mode at any time, do the following: 1) In the Apple menu, choose Restart or power on your Mac. 2) As the computer restarts, hold down the Command (⌘) – Option (⌥) – R combination immediately upon hearing the startup chime. Hold the keys until the animated globe appears on the screen.
This may also be a virus.
If you can save your user folder to an external. Then, In recovery mode do a reinstall of the system.
Fue útil esta respuesta?
Puntuación 2
3 comentarios:
Mayer,
Thanks for your attention!
I've tried this shift key during startup, the screen was black, I went to grab some snacks e after 10 min returned. The built-in screen was working, indicating Safe mode (red written). The machine performance seems to be very compromised (due to safe mode likely) while rendering screens and transitions for instance.
keyboard backlight buttons doesn't respond and volume control doesn't work (on keyboard). The brightness I manage normally tough.
When I close/open the lid the display responds fine.
I restart it in normal mode and the screen turns out to be black again
- de
The OS X is El capitain, it's a brand new installation
- de
I'm having a similar issue on a 2012 MBP. It will work fine with 10.9 but not higher. See if yours will do the same.
- de
I don’t know how to fix it but I have the same problem. Just updated a 2012 MacBook Pro to High Sierra while it was connected to an external display via thunderbolt to hdmi. Install went fine but now the internal display is not recognized. External LG tv works fine and when I go to displays and hold option key to detect displays the internal still isn’t available. Anyone ever ran into this?
Puntuación 0
3 comentarios:
I have the same problem; the "detect displays" button will not find the internal monitor and the machine is stuck to the external display (even after un-plugging / plugging in the Thunderbolt to HDMI cable). Did you ever find a solution that didn't involve a system restart?
- de
Same problem on my Macbook pro 2015, looking for a solution still!
- de
i have same problem did you find solutions?
- de
So, I updated my osx to High sierra - and I am running into this issue every now and then.
Sometimes my display just refuses to be detected, and then sometimes it does.
And when its detected - once it goes to sleep and at the time of waking up - password screen deos not come up - it just shows fading in white and then turns entire white. and stays frozen.
When I restart it from there - display is gone. but external display would work. restearts also dont work.
And then if I shut down - for a good 8-10 hours - it comes back.
NOt sure what it is.
Anyone else ??
Puntuación 0
3 comentarios:
So, I unchecked “Automatic graphics switching” Under System Preferences >> Energy Saver. And it basically resolved my issues.
I guess - unchecking that checbox always selected the best GPU for your display without thinking of your battery. which means you have high battery usage.
This must a software issue and probably upgrading os should resolve it. I am thinking to upgrade it to Mojave.
- de
Ninad your machine if a 2011, will not upgrade to Mojave
- de
@Ninad Desai I do this, but when restarting it goes back to "automatic graphics swhitching". What's happening?
- de
I will answer and you don't wanna like it: You need to change your motherboard if your connectors are plugged (which usually are because is not easy to unplug). In my case it worth.
Good luck anyway :(
Puntuación 0
1 comentario:
How much did you have to pay for the motherboard replacement? Or was it covered by your Apple Care?
- de
Same problem! Has anyone found a solution?
Puntuación 0
1 comentario:
My solution it was change the motherboard. It's a hardware problem, I just gave up and pay for it. Unfortunately.
- de
Añadir tu respuesta
Conrado Souza estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 6
Ultimos 7 días: 26
Ultimos 30 días: 149
Todo El Tiempo: 19,128
