Saltar al contenido principal
Las guías de reparación y soporte para todos los ventiladores mecánicos de hogar, incluyendo ventiladores de techo, de caja, de torre y verticales.
Preguntas 20 Ver todo
Fan blades turn slowly on Electric Window Fan-- how to fix?
The W B Marvin Mfg Company (of Urbana, Ohio) made wonderful window fans flanked by screens. The frame could expand sideways, so these fans fit into any window with a width of 22" or more (up to about 37"). Circulated the air, but kept the bugs outside!
I really like these fans, and I have several. One is not working well: the fan-blade assembly turns very slowly -- a single go-round takes about 3 seconds. I'm guessing that the motor needs to be oiled or to have some gunk cleaned out. Or maybe the problem is a bearing gone bad. Or...? Ideas? suggestions? instructions on how to fix this? I'm handy, but I've never done any repairs on small motors.
Too bad that Marvin Mfg went out of business.
Es esta una buena pregunta?
Puntuación 14
3 comentarios
Thanks for a different type of question.
- de
Yes I like it
- de
Replace capacitor
- de
Agregar un comentario
3 Respuestas
Solución Elegida
First, check to see that the fan blades turn freely by hand and coast after being spun. If rotation is in any way stiff, this is a sign of dirty, dry, or gummed bearings, which can slow the motor. Sometimes the bearings can become tight and binding which can also be an issue. You can possibly oil this.
Second, does the fan wobble at all? If for any reason the blade pitch is steeper on one or more blades than the motor is designed for, this will slow the motor. This can often be the cause of warping, or a blade being knocked off balance. This will also cause the fan to wobble or shake. You can bend the blades to a shallower pitch if they appear to be too steep, but be extremely careful as blade brackets can break easily.
Most fans made in recent years use permanent split capacitor motors, as they are efficient and reliable. However with age capacitors can drift in value. If the blades turn freely and are balanced, the cause of a fan running slowly is almost always a bad capacitor. The capacitor is a small black box or silver cannister with two or more wires attached, and is located inside the switch housing, motor housing, or inside a bell on top of the motor. It should be replaced with a capacitor of equal value, they are marked i.e. 6uf, 4uf, etc. Some fans have capacitors with two or more values, they should be replaced with the equivalent of those values by one or more capacitors
Fue útil esta respuesta?
Puntuación 20
7 comentarios:
good answer +
- de
Thanks! My quiet fan spins freely, no "gunk" or lube issues, but slow starting. After 5 minutes it runs whisper quiet and at proper speed all night. I'll check the capacitor and R&R same.
- de
Geez thank you..your a genius
- de
On target. Used a little WD40 to clean accumulated oil/dust from motor shaft/bearing and a little machine oil to lubricate and my old Air King window fan runs as smoothly as ever.
- de
Thanks,
The fan won't spin until I give it a spin manually and even then it takes a few seconds to for it to rock n roll.
After that it runs fine.
- de
Mostrar 2 comentarios más
The shaft needs some oil. its just dry. I came across this alot and oil it once a month and you can get 10 more yrs. out of it. do not put too much just enough to get it spinning again.
Puntuación 4
5 comentarios:
Dwayne S, check the age of the question. Hopefully this got fixed over the last 31/2 years
- de
oldturkey03 no matter how old the question is, it is is still a problem for others (like me) and the answers are valuable information that can last for years.
- de
cd barber, absolutely. That is why the answer is still there.
- de
Your suggestion was the key to getting my Honeywell fan turning again...thanks
- de
Why do people post this stuff about the age of the question, when the answers are still totally relevant? If it was about the performance of a sports person in a contest, fair enough, but about DIY questions that would been relevant 50 years ago? Electric motors haven't changed that much. All the types in use today were in use 50 years ago, afaik. Cosmetic changes, yes, but fundamental modes of operation?
- de
I have a small fan that run on small motor but the fan gives air backward
Puntuación 0
6 comentarios:
could be bad capacitor. If you can, give the fan a spin in the proper direction by hand then turn it on. If this works then it's a bad cap.
- de
reverse the power leads.
- de
my standing fun is workingslowly pls I need a solution
- de
"reverse the power leads." If it's AC it won't make a difference. Plus you could electrocute yourself if you wire it wrong.
- de
Reverse the position of motor not the power leads
- de
Mostrar 1 comentario más
Añadir tu respuesta
Julistra estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 10
Ultimos 30 días: 26
Todo El Tiempo: 161,175
