Why does my turn signal oonly work on one side?
Turn signal works normal on left side, but it blinks rapidly on right side and only the front light blinks.
Es esta una buena pregunta?
Hi Dennis,
A rapidly blinking turn signal often means that the light bulb is about to burn out. Try replacing the bulbs and see if that fixes your problem. This video might help with the replacement: https://www.youtube.com/watch?v=c0Rk3kh2...
Good luck,
Paige
Fue útil esta respuesta?
You need a new Turn Signal Switch, relatively cheap part
Bulb replacement solved the problem
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 121
1 comentario
Bulb replacement worked. Thank you
- de Dennis Johnson
