cranks over but wont catch
Got a 96,97 or a 98 Camry that cranks over but wont catch drove it last night went out today and it wont start
Es esta una buena pregunta?
michael, more info. may of helped engine,auto/manual any previous work done recently,etc. The first thing to check is there fuel in the tank, do you hear the fuel pump come on and cycle/ is the security lite on. You may have to have the vehicle scanned for trouble codes as a start as many things can cause your vehicle not to start, faulty crank sensor, Ignition module, coil packs, fuel pump, fuel pump relay, fuel pump, etc. Best to have a good Technician have a look, diagnose and estimate repair. Good luck. Link below may have more diagnosing procedures for you to check out.
Fue útil esta respuesta?
also check to make sure that the spark plugs are working correctly. often times if the engine is turning but the car is not coming on then the spark plugs need to be changed
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 13
Todo El Tiempo: 1,478
