cannot turn off /frozen!
HELP my bluetooth speakers have frozen and will not turn off,even when holding on/off switch down !
thanks in ad vance
Es esta una buena pregunta?
thanks in ad vance
The reset is inside the audio jack at the back. Took like an hour to put that together lol. Dont take it appart just push button and done.
Fue útil esta respuesta?
Hi, your advice on the position of the reset switch at the bottom of the earphone jack socket was a master stroke, as it’s a bit longer than an Apple key, I used a paper clip, felt it click and switched the speaker off, switched the speaker on normally all works fine. Thank you.
@alanlroberts yours was the very best! and it worked. The worst of it was the speaker is my dads and he has warned i should stop tampering with his stuff. Imagine my worry when his speaker froze.
Thank you very much. And guys in @alanlroberts advice,if you don't have a paper clip,you can use two pair of sewing needles
So helpful. I was push all the small holes on the top of the speaker but nothinh happen. No one tell details like yours. Never imagine the hole reset is on the audio jack. I was reading somewhere it can be the hole of mic indicator etc. So many holes but even in the manual they do not mention exactly the reset button itself. Thanks to you.
wooohoooo i fixed my speaker by the reset button thats located in the bottom of the aux port thanks to the above comments i now have my speaker back after days of confusion .
thanks
Who the !&&* posted this ansaer,? How in earth did you even get there??
Well this was very useful, you've saved me from the earth if my mom
It happened to me yesterday. My bluetooth speaker was frozen. So I let it for 10 hours until all its battery go down and then it turned off. After that I turn it on.
It happened to me today?.my bt speaker was frozen .
Worked for me on my Antimi Bluetooth speaker! I cut the pointy end off a round toothpick and used that to reset via the headphone jack. It was quite easy. Letting it drain the battery down completely works, too, but takes too long.
How did you Discover this.
It worked for me thanks
Worked for me on my Antimi, as well. The part about cutting off the pointy end is important, it won't work if you keep the point on the toothpick. Thanks for this tip, Tony!
I pushed the audio jack hole to reset my Bluetooth after it hanged, now its not charging and its not switching on again. Its overheating whenever I charge it
Guys, i have a Lenovo Thinkplus K3 which has freezed during my try to make it stereo with the other one.
and it doesnt have audio jack or reset button.... what shall i do????
Yes it happens to me I was having a fit but I stuck a pin in the aux and pop the button now every thing is 👍😊😊
Ultimas 24 horas: 26
Ultimos 7 días: 164
Ultimos 30 días: 650
Todo El Tiempo: 81,244
7 comentarios
You can try this, it worked for me. I just let me battery run all the way down. Recharge and that has seemingly fixed the problem.
- de drunken_stumbles
Does anyone know how to reset a Gooodmans waterproof speak mine won’t turn off
- de Morgan loves bts
Please I really need your help.... Was playing my UE roll 2 speaker ,its went off immediately I plucked the charger.. For the past 1week its not turning on or charging
- de Madison Adams
The last time something like this occurred... Its started charging and turned on after a month or more than without any repair... Thanks in advance
- de Madison Adams
My BS-218 was playing very nicely when it said my battery was getting low. I charged it and was attempting to play it again. When I powered it up, it said in slow motion, Bluetooth mode. Thats all I can get is slow motion response. Pls help.
- de David Reynolds
Mostrar 2 comentarios más
