Saltar al contenido principal
Lanzado originalmente en 2006, NeatDesk es un escáner de documentos de escritorio con ADF y funciones de dúplex completo. La revisión anterior tiene el número de modelo "ADF-070108" y la revisión más reciente es el modelo "ND-1000".
Scan and pdf led's both light on power up...non responsive
The main desktop scan unit "SCAN" and "PDF" LED's found on the desktop scanner body both light green upon power up. The led buttons are not jammed. Pushing the buttons will not change the lights. Adding paper does not help. Toggling the outside on off switch does not help. Plugging the USB wire into the unit and connecting to a computer does not have any effect. The computer runs Neatworks version 5.4 and now 5.7. Toggling on the soft "scan" button in software results in gettingt a message that the scanner is not available. No amount patient switching on or off the button helps. There is no reset button visible. The unit has no fractures or loose parts within. I have poked about and pulled off the plastic paper feeder sheets to see if there is a roller/feed jam but can find nothing. There is a plastic carrier bar inside the lid of the unit. It is not jammed. it springs back and forth a bit in a normal fashion when I push on it. The unit is not yet disassembled. Recollection indicates the unit may have been dropped recently on a soft wooden floor from desk level but there is no outward sign of damage. I suspect a loose connection somewhere within. But maybe others have some experience at this effort to unjam the machine before I attack it.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 1
2 comentarios:
Have you tried connecting to it with a different device if you have one?
- de
It does not matter. Plugged in or not to the port, the two LED's light up when I switch on the on/off switch. When I connect...no change. There is no communication along the USB line at all because the scan/pdf switche system seems frozen ON. I've looked into the unit and pulled off a few forms to inspect for stuck fittings. There are none. Next step...take off screws on plastic housing and check wires. But I don't have my tools handy. Nothing rattles. Why would I get power to both LED's even before putting in paper. Could both the little switches have been jammed ON somehow
- de
Agregar un comentario
1 Respuesta
If your NeatDesk™ Desktop Scanner has both the Scan and PDF LEDs lit on power-up and is unresponsive, here are a few troubleshooting steps you can try:
1. Power Cycle the Scanner
2. Check the USB Connection
3. Restart Your Computer
4. Update or Reinstall the Drivers
5. Try a Different Computer
6. Factory Reset the Scanner
Alternatively, if you want to scan a document and edit it as a PDF, you can also use a PDF editor program such as SwifDoo PDF.
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
steve johnson estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 6
Todo El Tiempo: 432
