How many wraps should I do on my first RBA
I'm building my first RBA and I am confused to what I should do in the way of wraps.
What should I wrap with without buying anything? and how many wraps should I do?
Es esta una buena pregunta?
Hi,
I may suggest a Ohm Tester to test your coils before installing, also to make sure they work.
Ohms is the resistance of the wire your using and usually it depends on what kind of vaper you are.
I suggest using a coil wrapper but, you could also use a plain screw driver, if the coils are too big, you could use a smaller diameter screwdriver. Usually beginning do 6 wraps and sub ohm vapers do complex builds ranging from 4-16 wraps, but it all depends on how much vapor you want.
Fue útil esta respuesta?
thxxxxx cant wait to build
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 221
