Saltar al contenido principal
Información y guías de reparación para el iPhone 6 que salió a la venta el 19 de septiembre de 2014. Números de modelo: A1549, A1586 y A1589
Preguntas 4994 Ver todo
Black Screen. Not recognized on itunes
My IPhone got wet, not dropped in a puddle or anything but had water spill on it. But nothing was really wrong except for some water marks on the screen. But the next day when i was using it it just went black. It wont vibrate, it could get recognized by itunes at first a week after it went black but now it wont be recognized, vibrate, or show anything on the screen(battery or plug into itunes). I tried holding the buttons and all that. Help....:o
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
2 Respuestas
Solución Elegida
First, unplug the battery connector. That can prevent any more destruction to your phones innards. Now take out the logic board. What you will want to do is place it in 90% or above isopropyl alcohol (rubbing alcohol) and brush it gently with a new toothbrush. Let it sit for five minutes. (In the alcohol) Then take it out and let it sit under a fan or in the sun for an hour. See if it works. If it doesn't, test the battery voltage. If it is above 3.6v, it is good. If you get no voltage or something below 3.6v, replace the battery.
Fue útil esta respuesta?
Puntuación 2
1 comentario:
Thank you I'll try that. :3
- de
Hello,
Water is the worst thing to electronic components. You said the phone is still working, but no image. My advice is turn of the phone imediatly because of short circuit on motherboard, if that happens, the phone is dead. Go to repair place for them to see what can be saved. I think for know, you only need to replace the screen and make a clean/ dry on the other components of the phone. Switch off the phone and don't turn on.
Puntuación -2
1 comentario:
The phone already won't turn on, they already said that. Also, just if a short circuit happens, that doesn't mean the phone is dead. Please don't post an answer unless you really know what your talking about.
- de
Añadir tu respuesta
Diabolical Baby estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 3
Todo El Tiempo: 970
