Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
The third-generation Ram was unveiled on February 7, 2001 at the 2001 Chicago Auto Show. This was a major update including an all new frame, suspension, powertrains, interiors, and sheet metal.
Why does my heater/air conditioning blower just work sometimes?
When I turn the blower switch on, sometimes it works other times it does not, when it works it works correctly on all speeds, when it does not, nothing comes on.
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
1 Respuesta
Solución Elegida
Randy, Intermittent blower motor problems, try moving/wiggling the key around with ignition on to see if that effects the blower motor, if it does the ignition contacts/wire could be bad. Other problems could be the blower motor resistor(common problem) or blower motor itself, the switch could be the problem but not common as others.
Fue útil esta respuesta?
Puntuación 1
Añadir tu respuesta
Randy Wilson estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 7
Ultimos 30 días: 25
Todo El Tiempo: 7,839
