Saltar al contenido principal
El enrutador inteligente Wi-Fi de doble banda Linksys EA6900 es un enrutador inalámbrico de cuatro puertos con tres antenas en la parte posterior del dispositivo. El dispositivo también cuenta con dos puertos USB (3.0 y 2.0) para almacenamiento de memoria.
How can I reset the Wi-Fi network?
I forgot the password to Wi-Fi network I had set up a long time ago, how can I reset the password?
Es esta una buena pregunta?
Puntuación 5
Agregar un comentario
3 Respuestas
Solución Elegida
Since you forgot the password to Wi-Fi network, you need to reset the Linksys EA6900 to factory defaults. There are two (2) ways do this:
Hardware Reset
Press and hold the Reset button on the back panel of the Linksys Smart Wi-Fi Router for about 10 seconds then release.
Software Reset
Log in to your Linksys Smart Wi-Fi Account. Under Router Settings, click Troubleshooting > Diagnostics. Click Reset under Factory reset.
Fue útil esta respuesta?
Puntuación 0
Respuesta Más Útil
Since you forgot the password to your router, you need to reset it to factory defaults:
There are two (2) ways to reset the Linksys EA6900 to factory defaults:
Hardware Reset
Press and hold the Reset button on the back panel for about 10 seconds then release.
Software Reset
Resetting your router means you are willing to lose following settings.
  • Router username and password.
  • Wi-Fi username and password.
  • Firewall settings.
  • Portforwards you have setup.
  • Any other changes you have made.
Puntuación 1
There are two ways by which you can reset the Wifif Network
  • Hardware Reset
  • Software Reset
Puntuación 0
Añadir tu respuesta
Rick Hsu estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 15
Todo El Tiempo: 8,957
