Saltar al contenido principal
Portátiles para juegos de alta gama producidos por Alienware (una subsidiaria de Dell desde 2006).
My laptop cannot power on.
My Alienware laptop cannot power on. No response after pressing power.
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
3 Respuestas
Solución Elegida
derekseven you want to start off by checking the output of your AC adapter with a multimeter. If the output is correct for your model (you did not tell us which model you have) then you need to consider taking it apart and measure/check the DC in connector. Try and trace the power loss from there on. If you give us your computers model number we may find a more direct answer.
Fue útil esta respuesta?
Puntuación 2
ive got a similar issue , what model do you have??
cheers
Phil
Puntuación 0
Same issue with a r2 15 , gtx 980m. It stopped whilr i was gaming and didn t start back. Doesn t turn back on.
Puntuación 0
Añadir tu respuesta
derekseven estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 2
Todo El Tiempo: 317
