Why wontmy iPhone 5c charge
i replaced the screen on my iphone 5c now it wont charge or turn on. and checked the cord, and ichecked the charge port, its clean.
Es esta una buena pregunta?
Try useing a different cord, if still the same result check for debris In the port
Fue útil esta respuesta?
U also may want to gently blow into the port if it still doesnt work go to the Apple Store
ya, used a few different cords. they all work on my husbands phone and the port is clean. it work fine until i put the new screen in.
Ok, check if the speakers are working, i think the speakers and the port are connected, ifixit has a teardown video, imwould watch it amd see what they think
Don't tell others to blow into any ports it causes corrosion / water damage / rust on the pins.
The better solution is to use a toothpick or something equivalent to clean out any dust or gunk / lint from the charging port if the charging cable does not plug in fully.
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 3
Todo El Tiempo: 66
