Saltar al contenido principal
Modelo M2453 o M6411 / 300, procesador 363 o 466 MHz G3
Preguntas 64 Ver todo
A new operating system for a new hard drive
I recently replaced the 6GB hard drive on my iBook g3 Clamshell with a new 30GB hard drive. The new hard drive is blank, so when I start up the iBook I get a gray screen with a folder that has a question mark on it. I have tried inserting an install disk for Mac OS X 10.4 and one (burnt CD) for Ubuntu Linux. I used an external CD/DVD drive because my iBook only has a CD drive built in. I have tried using both the built in drive and the external drive, and have held the 'C' key when starting the computer up, but I still get the gray screen and a question mark folder... Am I doing something wrong?
P.S. My iBook is the 1999 model. It has a CD ROM Drive built in, one USB 2.0, Internet (phone and ethernet ports,) one new 512 MB RAM (new) that replaced a 256 MB RAM, and Airport. It does not have a firewire port. (If that info helps)
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación -1
Agregar un comentario
2 Respuestas
Respuesta Más Útil
Obviously the Book is not seeing the disks that you're trying to boot from. Try using a 10.3 system as you do not have the firewire required by 10.4.
To use Mac OS X v10.4, your Macintosh needs:
A PowerPC G3, G4, or G5 processor
Built-in FireWire
At least 256 MB of RAM
DVD drive (DVD-ROM), Combo (CD-RW/DVD-ROM) or SuperDrive (DVD-R) for installation
At least 3 GB of free disk space; 4 GB if you install the XCode 2 Developer Tools
http://support.apple.com/kb/ht1514
Fue útil esta respuesta?
Puntuación 1
1 comentario:
Excellent answer +
- de
10.04 versions:
http://cdimage.ubuntu.com/ports/releases...
(the long term release version)
or
http://cdimage.ubuntu.com/xubuntu/ports/...
(also LTS +uses the less demanding XFCE desktop)
Xbuntu might be better, strongly recommend it since it is less demanding on the system. Esp. if you mac shares it's system memory with the graphics card. I am not sure but my guess is it does. I can use 800MB of RAM on my Ubuntu system without even trying. (web browser, email, skype).
choose the correct CD image for your machine and it should work.
Due to the age of the computer you may have some problems with the graphics driver or maybe sound. Being familiar with the command line would be a bonus if you need to fix something without a graphical environment. The ubuntu forums are your friend, everyone finds solutions to problems there.
The linux part I can offer some info, I work with newer macs and have yet to have an install problem, i never dealt with the model you have.
I am not sure your mac supports booting from USB, prob. only firewire, I am not sure thou.
Someone here that knows more about macs might be able to offer an idea of using another computer to install mac os over a network (Ethernet connection).
OR
best option would be cloning/imaging your original hard drive and applying that image to the new hard drive. Free one called drive image XML should work I have used it before.I have also used others. Your old hard drive is in good health so start with the Drive Image xml and if it doesn't work try another.
here is a list of drive imaging tools:
http://mysoftchoice.com/c/backup_tool/cl...
Seems like it would be your easiest and best option for your mac OS install with the equipment you have listed.
(and don't make it hard, I have left my own laptops with hard drives partially installed in a safe manor while imaging, all you need is an external hard drive or in some cases an available network share)
Puntuación 0
Añadir tu respuesta
Kevin estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 2
Todo El Tiempo: 1,342
