Why is oil light on
The oil light is on I changed oil and its still on
Es esta una buena pregunta?
I would check the oil sensor. Since you know it is oil in the engine I would check the sensor first!
Fue útil esta respuesta?
Is oil sending next to distr.
I UNPLUGED the sensor and the light went out. That made me remember i replaced the sensor about ayear ago it was leaking oil and now its gone bad all together going back to advance to see if they will replace it.?
Zoso, there is a few reasons for an oil warning light to be on in your truck, oil could be low, oil sending unit faulty, oil pump could be faulty, clogged oil passages, worn internal engine bearings, etc. If you do not presently have a mechanical gage to read oil pressure, it would be a good idea to hook one up to see where pressure is at to help diagnose problem or take into a good shop and have them do it, diagnose and estimate repair.
Now if you are talking about a change/service engine oil light found in later models, after changing oil the light must be reset turn on ignition to on with out engine on, press the gas pedal down 3 times, holding pedal down on third press till oil indicator displays oil life reset.
Hope this helps, good luck.
Where is oil sending unit next to distr.
Oil sending unit may be by Distributor or possibly by oil filter. I will post a link to a pic. of what it looks like.
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 14
Todo El Tiempo: 600
