Saltar al contenido principal
Guías de reparación y soporte para placas base y CPU.
Preguntas 154 Ver todo
Common motherboard failure points?
So far I've had two or three cases where a PC motherboard just stopped working for no apparent reason. In one case, somebody jostled the system hard enough to disengage the CPU heat sink. In that case, I thought to myself "This is a slam dunk. Just replace the CPU." In all of those cases, the replacement CPU was cheap enough that I figured, what the heck, let's do it. I followed correct procedures (anti-static, thermal paste, etc.), but in none of these cases did the CPU replacement bring the system back to life.
Is there some component on PC motherboards, besides the CPU, that tends to fail more frequently than others? Something to test that might lead to bringing the boards back to life?
Thanks.
Es esta una buena pregunta?
Puntuación 1
2 comentarios
What board, what CPU? Any commonalities? You did try different PSU's etc>?
- de
if theres "no signs of life" i usually check the power supply, cos if theres an issue with the board or another component it will generally beep at you when trying to start.
- de
Agregar un comentario
1 Respuesta
Solución Elegida
Usually if it's not the CPU, it's the GPU. Test with an external monitor.
Fue útil esta respuesta?
Puntuación 3
Añadir tu respuesta
TheGear estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 1
Todo El Tiempo: 932
