Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
El iPhone 5s de Apple fue anunciado el 10 de Septiembre, 2013. La reparación de este dispositivo es similar a los modelos anteriores y requiere destornilladores y herramientas de palanca. Disponible como GSM o CDMA /16, 32, o 64 GB / Plata, Oro, y Gris Espacial.
Distortion when using headphone
I've got an iPhone 5s and when I plug in my headphones, there is an awful distortion. I replaced the headphone jack/lightning assembly with the same result. The problem is that if I don't push the headphones in all the way, they sound fine. It's just the last "click" where it goes wrong. Anyone have any ideas?
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
4 Respuestas
Solución Elegida
Alex, Try a different set of head phones, making sure it is compatible with your I phone, some of the connection tips vary in size and shape and yours sounds like it is not making proper connection.
You can also try this at your own discretion, with a pair of pliers bend the tip on head phone pin slightly and try.
Fue útil esta respuesta?
Puntuación 1
Use toothpick.
Also use a ear-swab (with some alcohol).
Then see if you can get the sprig out in the proper position.
It is probably stuck. That's the piece that holds the plug in place.
You should see it when you look inside with flashlight and magnifier.
Puntuación 0
I already replaced the jack so it shouldn't be an issue. I'll give it a shot either way.
Puntuación 0
I'm having the same issue.
Puntuación 0
Añadir tu respuesta
Alex estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 6
Ultimos 30 días: 24
Todo El Tiempo: 1,394
