When I turn on the green light will blink but nothing else
The green light will turn on for less then a second when I switch the power supply on, but then nothing, please help
Es esta una buena pregunta?
Hey Russell,
Try a hard reset of your system if you don't mind. While the system is turned off, hold down your power button until you hear the second beep. See if that fixes it. If not, let me know.
Fue útil esta respuesta?
I can't hard reset as it seems no power, when I switch on the main plug it will flash green once, but then that is it. Nothing else
Can't eject the disc, it won't take a disc, and holding the button down for 45 seconds produces nothing?
Nothing at all
Anything else I can try?
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 2
Todo El Tiempo: 99
To clarify, nothing appears on screen when this happens?
- de Ben Eccles
It just doesn't turn on at all, only a flicker of the green light
- de Russell
I can't hard reset as no power. When I switch the main plug on, a green light flickers, that is all
- de Russell
