Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
El primer modelo de iPhone, modelo A1203 con 4, 8 o 16 GB de capacidad y una parte posterior de aluminio. La reparación requiere una cantidad significativa de destreza, y puede requerir un poco de soldadura.
ear speaker not working
can't hear anything from the ear speaker. what should i do?
Es esta una buena pregunta?
Puntuación 2
Agregar un comentario
1 Respuesta
Solución Elegida
Hello, Had the same problem. I solved it myself it's pretty easy. The headphone port on top of the phone collected lint and fibers from my clothing like your jeans pocket. The lint got in between the contacts of the headphone terminals so it was open circuit so the sound was cut off. Just remove back cover unscrew headphone port clean inside with tooth pic using the pic to remove as much lint and fibers as possible the spray some electronic contact cleaner into hole flooding it so it pours out. Use plastic friendly cleaner as the plastic housing would melt, the can must say plastic safe. Hopes this helps. CHEERS /Randy from Trinidad
Fue útil esta respuesta?
Puntuación 3
2 comentarios:
hi randy, thanks a lot. i'll try it.
- de
Thanx. Got the same problem and I'm gonna try your solution. great.
- de
Añadir tu respuesta
manny estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 4
Ultimos 30 días: 30
Todo El Tiempo: 2,644
