Why is my phone dying while charging?
Ok so i've been having problems with my IPhone Today. So recently i got Qi Charging but the wireless reciever was a little wierd and acting up so i decided not to use it. Today i decided to give it a try again and my phone dosen't charge properly now. Basically i went to go charge it on my personal charger and it wasn't going above 1% and it kept dying on the charger. So i decided to try my moms charger and the same problem kept happening. My guess is the Qi wireless reciever fried part of my Logic Board. I did lots of research and i found tutorials on replacing logic boards and fixing certain parts of my logic board. I don;t to replace my logic board because they're basically the component that makes the iphone expensive they're around $300. Can someone tell me what the name of the part of the logic board would need to be fixed or if there is a way to fix it without opening it. i am running IOS 9.3.3. I would appreciate the help since my IPhone is a daily necessity for me.
Es esta una buena pregunta?
Probably the Tristar U2 charging IC chip. I'd get the phone looked at by someone that is professional and does board level iPhone repairs.
- de Ben
Where could I find a professional I usually get my phone fixed at malls which is a bad idea probably but it's usually just easy stuff like screen replacement and battery replacement but I wouldn't trust them poking around a logic board
- de Aaa
What country are you in? There may be others here that can point you in the right direction in terms of where to find one near you.
- de Ben
I'm in USA NY Long Island
- de Aaa
UPDATE: I have an app that tells me the durability of my battery. It's showing nothing so I'm guessing that the chip it uses to read that data is the one that is broken the app is called BatteryLife hopefully this gives your a better idea of what the chip that is damaged is called
- de Aaa
