Saltar al contenido principal
La HP LaserJet 1200 es una impresora láser monocromática producida por Hewlett-Packard.
Preguntas 10 Ver todo
USB Printer Port to connect to computer is not working
The printer works but the power between the printer and the computer is dead. I am certain it is the USB Port Prongs that are the problem. I have tried several other cords and still get the same outcome: nothing. Can I simply change out this port? Where can I buy this port replacement? Many thanks!
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
2 Respuestas
Can you tried an USB-HUB? If not, try to use a USB-HUB to try at first.
Fue útil esta respuesta?
Puntuación 0
Since your USB port appears to be non-functional, I suggest switching over to printing via the network, print server, or WiFi using the HP JetDirect port. You may need to purchase something extra to get this to work, but is easier than resoldering a USB port.
Puntuación 0
Añadir tu respuesta
Katharine Atchley estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 12
Todo El Tiempo: 528
