Saltar al contenido principal
The Golf Mk4 was first introduced in August 1997, followed by a notchback version (VW Bora or, in North America, again VW Jetta) in August 1998 and a new Golf Variant (estate) in March 1999.
Preguntas 34 Ver todo
Broken cigarette lighter - Fuse problem?
So the light around the rim comes on when I turn the lights on, but it doesnt seem to work. Tried plugging my sat nav in and got nothing, although it works in other cars. What do I need to do and how? Please help me
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
2 Respuestas
Solución Elegida
Yes
it could be a fuse. Look in fuse box for blown one - often inside the cover of the box it tells which fuse is for what.
If the new fuse just blows out then there's a short in the unit (or wires leading to the unit). If you find the short it may be repairable, or you may need to replace the unit.
If this answer was helpful please remember to mark it accepted.
Good Luck,
N
Fue útil esta respuesta?
Puntuación 1
3 comentarios:
The light in the rim and the lighter itself are two different circurits. As said before look for a blown fuse.
- de
To add to the info above: Power outlet is #26 (20amp) and the Cigarette lighter is #24 (25amp)
- de
Only have 22 fuses, none marked 12v outlet, car does not have cig. Lighter.
Light around outlet does not light up,
2002 G L X.
Unplugged from back no power, which fuse should it be?
- de
Hello I have a problem in tidying up not working for four golf 4
Puntuación 0
Añadir tu respuesta
Krystyna estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 11
Todo El Tiempo: 8,214
