Saltar al contenido principal
Este dispositivo es una máquina de bebidas caseras fabricada por SodaStream. El propósito de este dispositivo es hacer bebidas gaseosas en la comodidad de tu casa con el uso de jarabes y la máquina. Este modelo en particular fue fabricado originalmente en aproximadamente 2007.
Leaks when making soda
when making soda, the gasket located where the bottle screws in is old and hard.
the soda leaks down the bottle and onto the counter.
i cannot find a replacement gasket on line??
cujim
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
2 Respuestas
Respuesta Más Útil
I used Sugru, which you can buy on Amazon or Target and made my own gasket. The object is to not make it so thick just about a string of 1/4 inch Surgru around the inside, screw the bottle in just enough to make a slight screw impression and then take the bottle out and let it dry for 8-10 hours.
You've now made your own gasket with a rubber material that will last a couple of years.
Fue útil esta respuesta?
Puntuación 1
2 comentarios:
Thank You! I will try it
- de
FYI - I found so many soda streams in garage sails and/or on the stoop in the street of Brooklyn ..
- de
iFixit doesn't carry them; I'd check with Sodastream to see if they sell a replacement. You might have some luck in taking the gasket to a hardware store and see if they have a similar gasket.
Puntuación 0
Añadir tu respuesta
JIM Nichols estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 20
Todo El Tiempo: 1,635
