Saltar al contenido principal
La Toshiba Satellite C655D-S5084 es una computadora portátil de costo medio que forma parte de la serie Toshiba Satellite C650. El C655D-S5084 es una versión personalizada del modelo base.
Preguntas 10 Ver todo
Turns on and off when booting
I scored a Laptop for nothing but it has a problem where it will not boot at all.
I am told at some stage someone replaced the RAM but and instantly stopped working.
When you try to turn it on it has power and attempts to boot but the screen stays black and after about 10 seconds it turns off again?
I have reinstalled original 4GB of RAM and removed the HDD to see if it would take me to the BIOS, but nothing seems to work.
Any suggestions would be helpful thanks.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Is there multiple slots to install the Memory? Could be that the slot you are using is bad. That or the memory isn't currently seated all the way in the slot.
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
Harley Greaves estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 105
