Replacement screws, how do I measure them?
Hello guys, this time I am here to know if there is an easy way to measure the screws in a set of replacement screws for iPhone 5s.
Thing is I only need the ones holding the home button bracket (1.4mm #000 phillips); the ones holding the battery connector bracket (1.6mm #000 phillips); the ones holding the front panel assembly cable bracket (1.7, 1.7, 1.3 and 1.2mm #000 phillips); the ones holding the earpiece speaker bracket (4.0 and 2.3mm #000 phillips); and the one securing the back of the display assembly to the LCD plate shield (2.7mm #000 phillips).
So I need to know which one is which.
Any help?
Thanks.
Es esta una buena pregunta?
