Can ingress 68 be retored after battery replacement
The Note 7 has ingress 68, but is sealed with adhesive. Can the ip68 ingress be restored after battery replacement?
Es esta una buena pregunta?
Yes it can be resealed and still be ipx68 (water dust resistant.
You must use the right tools when disassembling and during reassembly.
Use heat gun or hot air station to heat the back glass just to when you can't touch it using playing cards and thin metal pry tool slowly break adhesive seal.
Remove battery
When re assembling the phone be sure to use a water resistant adhesive.
3M makes adhesive and tapes that can reseal back
The biggest thing is heat back glass and and adhesive slightly prior to install then place paper or something over back to protect it then set something heavy on it I used wood clamps with adaptors to keep tight equal pressure on entire back let it sit like that for 2 hours and it will be resealed against dust and water.
A little more extensive and cost more but but just sticking back back on using old adhesive will not reseal correctly
Fue útil esta respuesta?
If it's done professionally, then yes I.e. if Samsung replaced it
Ultimas 24 horas: 2
Ultimos 7 días: 2
Ultimos 30 días: 18
Todo El Tiempo: 782
1 comentario
By sealing the Note 7, with cement Samsung has increased its cost for the battery recall. It cannot sell the swapped phones as new. Only if they repair and then send back the resealed phones can they reduce the recall costs.
- de Howard Pon
