Why is troy bilt spray oil from air fliter
why is troy blit spray oil from air filter
Es esta una buena pregunta?
Puntuación
0
There is a breather pipe into the air filter and because of this, you will always get some oil into the filter. What I have found to be the problem on the ones I worked on was too much oil in the engine. It is only supposed to be filled to the line on the sight glass.
Check the oil level.
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 11
Todo El Tiempo: 365
