tablet wont authenticate with my broadband
tab2 a7 wont connect to my broadband it keeps going authenticating to failed.broadband provider says a problem with my harddrive
it wont connect to internet.what can i do
Es esta una buena pregunta?
Its most likely that you didn't type in the password right. Then there is the super simple answer: Are you sure you have wifi? What broadband provider do you use and what modem/gateway/router are you using?
Fue útil esta respuesta?
with ee. wifi turned on and using ee router
well done josh you were right.i typed the wrong hyphon in.you are my hero
rule #1: Its always something simple until I'm proven wrong.
I also may have spent hours cussing out a new laptop that won't connect only to realize that I missed a digit on the password.
May be the problem is in the password? CapsLock was on or something like ths?
Did you check your wi-fi router or call your provider ? In order for the Internet to work well in the router, without failures, it is necessary that the fiber line is very stable. And this stability is very difficult to find. I also faced such a problem and searched for a long time for a provider that would provide a choice. And found, this is https://usave.co.uk/broadband/ . They have different packages with different speeds and different prices. After installation, everything worked very well. So I advise you to do the same. This is a good way out of the situation.
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 78
