It wont respond at all?
Its plugged in and the breaker has NOT tripped but when I push ANY button it does nothing. It's like its dead HELP
Es esta una buena pregunta?
Lid switch
If the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it.
Some machines have a special lid-switch fuse near the lid switch, inside the control panel. If this fuse blows, the unit won't fill with water until you replace the fuse.
Fue útil esta respuesta?
Good answer +
We sometimes have to turn off the breaker switch in the basement that powers the washer, and then switching it back on seems to be all that is needed to "wake it up."
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 7
Todo El Tiempo: 1,204
