Saltar al contenido principal
Modelo A1502 / 2.6 GHz (Turbo Boost hasta 3.1 GHz) o 2.8 GHz (Turbo Boost hasta 3.3 GHz) procesador Intel Core i7 de doble núcleo con 4 MB de caché L3 compartida.
Preguntas 494 Ver todo
Battery Removal tools required for MacBook Pro 13" Retina 2014 model
Hi,
At some point in the past, my Macbook fell off the bed and apparently dislodged the battery from it's connection point. Symptoms were dead Macbook and charge indicator LED wouldn't go green or amber (to show battery charging status). I brought it in to BestBuy (warranted repair at that point).
Just recently, the same issue has occurred. I assume it must have somehow disconnected again.
I came across this website but don't see a specific video for my laptop. Does anyone know the exact tools to get into and fix the battery issue?
Thanks!
Andy
Es esta una buena pregunta?
Puntuación 0
1 comentario
I've fixed your system info so its now pointing to the correct guides.
- de
Agregar un comentario
1 Respuesta
Solución Elegida
Before you open the system up lets make sure the MagSafe adapters connection is good.
  • With the adapter disconnected inspect the pins within the MagSafe cord end using a small screwdriver press each pin slightly do they spring back?
  • Looking at your computers MagSafe connector are the contact pads clean and shiny? Is the plastic look melted or deformed at all?
Now lets check the MagSafe adapter its self. Is the DC side cord damaged in any way? Bumpy, insulation cut or wires exposed? Often I find the cord is damaged which in turn damages the delicate electronics internally in your system.
Let us know what you find.
Fue útil esta respuesta?
Puntuación 2
Añadir tu respuesta
Andy Martin estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 4
Ultimos 30 días: 4
Todo El Tiempo: 110
