Need to find value for component
Hi!
Is anyone able to help me with the value of the component in the diagram for Samsung Galaxy S6 Edge (SM 920F) ? (see arrow).
Thanking in advance!
Es esta una buena pregunta?
Hi!
brandonsucess your posted image helps, but leaves a lot of detail out and it is confusing. Next time consider posting true images from your device ;-)
The image you posted is not from a SM-G920F but is a SM-G925. There are lots of differences on the component side between those two models. The one you are inquiring about is reference designator C9037 which is Samsung part number 2203-007796 which is a 1000nF 20% 10V capacitor. Samsung does not post the component values on their schematic but uses a secondary code for the components. Not always an easy chore. Anyhow, good luck.
Fue útil esta respuesta?
Thank you very much. First time posting anything like this so please accept my apologies for diagram... I may have misquoted as I was posting this on behalf of my colleague & perhaps the the model incorrect.
Thanks heaps!
brandonsucess no big deal. A good images just helps us on here to find the answers a bit quicker since we would not have to identify the board. At least you had an image;-)
Could you specify just a notch??
an arrow pointing on a socket board with maybe 1000 small components is not easy to figure out which you think os.. is is the one right underneath the arrow or is the arrow maybe pointing towards, the green lines and we should actually follow those to there ending spot.. and is it then two components you want the price on?
if so, do you have some info about it??
to a start i think you should try for your self and look through this website.. http://rs-online.com there is only millions components to go through. so if the maybe seems like impossible, then maybe try bring out som more info..
what is broken on the phone,
which function do not respond. and bla bla bla...
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 3
Todo El Tiempo: 261
1 comentario
Thanks heaps!
- de brandonsucess
