Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Anunciado - 2014, noviembre El Samsung Galaxy Core Prime (G360, G361) funciona con un procesador de cuatro núcleos a 1.3GHz y viene con 1GB de RAM. El teléfono incluye 8 GB de almacenamiento interno que se puede ampliar hasta 64 GB mediante una tarjeta microSD.
My phone does not turn on
My phone read T-Mobile update available when I tried to update the phone it says update failed at 92% now the phone won't turn on. When I press the power button it vibrates and shows the Samsung Galaxy Core Prime powered by android screen and is stuck there.
I am located in the Caribbean at the moment.
Can you help me with this problem I have only had the phone for about 6 months
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 3
Agregar un comentario
2 Respuestas
Respuesta Más Útil
I would try to clear the cache partition in recovery mode. To do this you first need to boot the phone in recovery mode.
Press the Power, Home, and Volume up buttons at the same time.
Release all key when Android or Samsung logo appear then you will see Android System Recovery.
Navigate with the volume keys, and select with the power button.
Navigate to wipe cache partition, and select it.
Wait for that to finish, then reboot your phone.
Hope that helps :)
If it doesn't work though, i would do a factory reset using the same method, unless anyone else has a better answer. (The factory reset will erase ALL personal data from your phone. So it should be a last ditch effort.)
Fue útil esta respuesta?
Puntuación 2
2 comentarios:
I have the same problem too, but it didn't work. Although my updates didn't fail, but my phone ran out of battery and shutdown and i cant turn it back on again, have any ideas?
- de
i just bought the same phone today it is just turning on and off continuously
please help
- de
If also not solved your problem try to change volume keys
Puntuación 0
Añadir tu respuesta
candyluvcall411 estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 21
Todo El Tiempo: 2,419
