Is there a Manual firing option?
Can I manually fire the Nerf Dart Tag Swarmfire with the device not turned on?
Es esta una buena pregunta?
The power switch is found on the top of the Nerf gun near the stock end. The only way to use the Nerf gun is to turn the switch into the "on" position, it does not have a manual firing feature.
Fue útil esta respuesta?
You could if you found a way to put some sort of hand crank on it
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 3
Todo El Tiempo: 195
